STKO closes immediately
jpereirasan
Post by jpereirasan » Thu May 30, 2024 4:00 am
Dear STKO team, i have the STKO 3.3 version installed in my desktop computer.
When i try to open an external SCD file, the program load the model but immediately closes.
How can i fix that problem?
(i can open models that i builded in my computer but not external SCD files from tutorials or this forum)
Re: STKO closes immediately
Post by STKO Team » Thu May 30, 2024 7:25 am
That's strange. Is there a file from a particular webinar that doesn't work?
jpereirasan
Post by jpereirasan » Fri May 31, 2024 3:29 am
I downloaded all the models from the STKO Model Database, STKO only works with the first model 0001_fibercolumn, all the other models close STKO immediately.
I attached the screenshots of what happen when i open a SCD file
Please help me to find a solution or find what is the cause of this problem
jpereirasan
Post by jpereirasan » Fri May 31, 2024 7:42 pm
problem solved..... it was an issue with the GPU
Post by STKO Team » Mon Jun 03, 2024 7:49 am
Yes. STKO requires at least OpenGL 2.1.
SUOSUO
Post by SUOSUO » Sun Apr 20, 2025 2:59 am
hello,
I’m encountering the same issue, but my GPU should meet the requirements. Attached is my computer’s GPU information.
thanks.
屏幕截图 2025-04-20 105649.png (15.32 KiB) Viewed 3169 times
Post by STKO Team » Tue Apr 22, 2025 7:43 am
It's probably because you are on a laptop and by default applications start with the integrated GPU (which may not meet the requirements). Force STKO to start with the dedicated GPU (Nvidia in your case)
SUOSUO
Post by SUOSUO » Fri Apr 25, 2025 4:42 am
Just to update you, the problem is solved. Thanks!
Post by STKO Team » Mon Apr 28, 2025 8:16 am
