STKO closes immediately
jpereirasan
Dear STKO team, i have the STKO 3.3 version installed in my desktop computer.
When i try to open an external SCD file, the program load the model but immediately closes.
How can i fix that problem?
(i can open models that i builded in my computer but not external SCD files from tutorials or this forum)
Re: STKO closes immediately
That's strange. Is there a file from a particular webinar that doesn't work?
jpereirasan
I downloaded all the models from the STKO Model Database, STKO only works with the first model 0001_fibercolumn, all the other models close STKO immediately.
I attached the screenshots of what happen when i open a SCD file
Please help me to find a solution or find what is the cause of this problem
- Screenshot_3.png (215.82 KiB) Viewed 4747 times
- Screenshot_2.png (515.61 KiB) Viewed 4747 times
- Screenshot_1.png (42.57 KiB) Viewed 4747 times
jpereirasan
problem solved..... it was an issue with the GPU
Yes. STKO requires at least OpenGL 2.1.
hello,
I’m encountering the same issue, but my GPU should meet the requirements. Attached is my computer’s GPU information.
thanks.
thanks.
- 屏幕截图 2025-04-20 105649.png (15.32 KiB) Viewed 3171 times
It's probably because you are on a laptop and by default applications start with the integrated GPU (which may not meet the requirements). Force STKO to start with the dedicated GPU (Nvidia in your case)
Just to update you, the problem is solved. Thanks!
