DamageTC1D in Linux
amb_1
DamageTC1D in Linux
Post by amb_1 » Mon Jan 01, 2024 6:15 am
Dear SKTO Team:
Many thanks for your help with this.
When using DamageTC1D material, the material runs properly in OPenSees-Solvers. However, it doesn't work normally in the Linux version. The Linux version is compiled using github-opensees, is there a solution method?
For shear wall fiber damage, when Layershell is used, the NDmaterials ASDConcrete,and DamageTC1D can be used. However, for pile fiber section, concrete only DamageTC1D can show fiber damage with shear force and bending moment.
Thanks for your help.
Yours sincerely
ambcha
Re: DamageTC1D in Linux
Post by STKO Team » Tue Jan 02, 2024 2:50 pm
Unfortunately, the DamageTC3D and DamageTC1D are available as plugins but only on Windows and they are not in the official OpenSees repo.
That's why we started integrating them into their new versions ASDConcrete3D and ASDConcrete1D. However, the ASDConcrete1D is not available yet. We will add it shortly. In the meatine you should go with another 1D concrete material
amb_1
Post by amb_1 » Fri Jan 05, 2024 3:08 am
Dear STKO team
Thank you very much for your help. Developing such a perfect software as STKO.
DamageTC1D material is not available on linux systems.
If studying circular pile foundation fiber sections, fiber section damage, can you recommend an alternative material besides DamageTC1D material?
Looking forward to ASDConcrete1D materials!
Best wishes
Ambcha
Post by STKO Team » Fri Jan 05, 2024 8:50 am
You can use any other Concrete uniaxial material but none of them has the damage output
amb_1
Post by amb_1 » Mon Jan 08, 2024 7:25 am
Thanks for the suggestion and looking forward to the ASDConcrete1D material!
Post by STKO Team » Thu Jan 18, 2024 11:13 am
you're welcome
ragemanners
Post by ragemanners » Tue Sep 10, 2024 2:28 pm
I had a similar issue with DamageTC1D on Linux a while back. ended up using a different 1D concrete material as a workaround. Developer jobs are getting harder and harder!
Post by STKO Team » Tue Sep 24, 2024 9:36 am
Anyway, with the new version released yesterday the ASDConcrete1D is available
