Dear STKO
I know the reason why convergence is not possible. I often encounter this problem when using STKO, and I have solved it. It is very sensitive for grid size, all grids must be in the same size. Strangely, however, I do not see this problem when using the grid provided by other meshes software (GID, Hypermeh, abaqus). This is a strange phenomenon, as the last time I provided the grid provided by OPenSeesPL, it works regardless of the mesh deformity. I guess it is related to the grid partition of parallel computing. In other software, I used vertical partition, but I do not know how to realize the partition of STKO parallel grid computing.
Sorry, my theoretical basis is not very good. The reason why newmark sets parameters 1.5 and 1.0 is that I have seen from the literature that gravity balance recommends the selection of parameters. I have derived the calculation formula of newmark.
My models are all inclined, and the boundary has a great impact on my settlement results. The conventional shear beam boundary cannot be used. There are too many models to upload completely. I have provided an elastic model.
I'm sorry for I might have a little too many questions:
1, about InitialStateAnalysisWrapper, in the dynamic analysis of gravity balance simulation, some cases using (InitialStateAnalysis on/off), in some cases there is no use InitialStateAnalysis on/off), In opensees website (
https://opensees.berkeley.edu/wiki/inde ... s_of_Slope) and OPenSesPL website (
https://www.baidu.com/link?url=7Z2pPZDR ... 03637cedb9), however, according to the comparison of my simulation results, I found that sometimes the two results are similar, and sometimes they are quite different. Could you please tell me whether they are used in dynamic analysis?
- 1.png (80.28 KiB) Viewed 6206 times
- 2.png (56.21 KiB) Viewed 6206 times
2. In addition, I also encountered a problem that sometimes had a big impact on the results, and sometimes had a small impact. When the volume modulus and shear modulus are updated to large values in gravity equilibrium, to prevent large deformation (the principle is similar to that in the More-Coulomb constitutive simulation of FLac3D), and then updated to normal values before dynamic simulation, do you think I should use the updated volume modulus and shear modulus when using PDMY02 simulation?
3. According to the centrifuge test, should my boundary adopt the following scheme (1) or(2)?
- 3.png (135.35 KiB) Viewed 6206 times
- 4.png (129.74 KiB) Viewed 6206 times
4, I want to know my model the boundary of the material whether to adopt and shear box in the experiments of the same material (elastic) (HTTP: / /
https://www.researchgate.net/publicatio ... Pile_Group _response_subjected_TO_induced_large_ground_deformation_in_e-defense_shake_table_test), or PDMY02 (the same as below)? However, my model does not work, can you help me to look at it?
- 5.png (49.06 KiB) Viewed 6206 times
- 6.png (8.73 KiB) Viewed 6206 times
5. Should the width of the model box be the same as that of the test shear box? However, based on my recent research, I found that width has a huge impact on the results,
6. Opensees website provides a case study on how to simulate a real field, using free field boundaries, Boundary using PDMY02, it has a value of 10000 (
https://opensees.berkeley.edu/wiki/inde ... s_of_Slope), However, when I use different lengths in 3D to simulate the 3D is free field, the results of the model are very large due to different scales, and the impact on the results is very large. Could you please give me a suggestion on the range of values?
- 7.png (101.73 KiB) Viewed 6206 times
- 8.png (131.29 KiB) Viewed 6206 times
- 9.png (88.19 KiB) Viewed 6206 times
7. Could you please tell me the development of the elastoplastic energy absorption boundary (PDMY) version, when the lecture will be held? When is the update in new STKO version?
8. STKO is the best software I have ever encountered in learning openses. Regarding the use of STKO software, does the company have a separate software training camp? In addition, can we invite your company to carry out training and lectures?
Best wishes
