Different colors in the surface
Zamiad
Post by Zamiad » Thu Apr 17, 2025 2:28 pm
I am modeling a surface in stko, but I am noticing for the faces that has the same properties in one plane the color is different I mean some are more grey... like the attached picture.
Thanks,
Re: Different colors in the surface
Post by STKO Team » Wed Apr 23, 2025 1:04 pm
In a surface the color is darker if you are looking at it from behind.
This means that those surfaces have normal vectors in opposite directions.
Zamiad
Post by Zamiad » Thu Apr 24, 2025 10:04 am
Thank you,
how can I change it to make the color all the same?
Post by STKO Team » Mon Apr 28, 2025 8:19 am
Use the Reverse command in the Geometry tab
