I am modeling a surface in stko, but I am noticing for the faces that has the same properties in one plane the color is different I mean some are more grey... like the attached picture.
Thanks,
Different colors in the surface
- Capture.JPG (10.04 KiB) Viewed 2564 times
Re: Different colors in the surface
In a surface the color is darker if you are looking at it from behind.
This means that those surfaces have normal vectors in opposite directions.
Thank you,
how can I change it to make the color all the same?
Use the Reverse command in the Geometry tab
