Error message while creating input files
bruznunez
Post by bruznunez » Tue Sep 17, 2024 8:47 pm
I have been trying to run a model of a reinforced masonry wall, but it gives me the following error message when trying to run the model: "writeTcl() missing 1 required positional argument: 'xobj'. I need your help to solve this problem.
kind regards,
Benjamín
masonry_wall_02.zip
(166.72 KiB) Downloaded 60 times
Re: Error message while creating input files
Post by STKO Team » Tue Sep 24, 2024 8:31 am
There are some errors in your model:
Try to fix these 2:
  • Your geometry has some faces that cannot be meshed with structured quad mesh (they have more than 4 edges). If you want to keep it as it is, switch to unstructured triangular mesh, and choose a triangular shell element. Otherwise, cut your geometry to make it suitable for structured quad mesh:
    extra cuts.png (15.81 KiB) Viewed 504 times
  • You are using a uniaxial section for an elastic timoshenko beam: it's not correct. You should either use an elastic section with an elastic beam, or a nonlinear section (for example fibers) with a nonlinear beam column
Fix those first, and let's see if there are other mistakes
bruznunez
Post by bruznunez » Wed Sep 25, 2024 9:30 am
Hi STKO team,
I fixed the geometry problem and the problem with the top and bottom faces using a elastic membrane section in shell elements, but now apparently the problem is something else.
bruznunez
Post by bruznunez » Wed Sep 25, 2024 9:33 am
sorry, i forgot the picture and the model but here is.
Shear wall_RM-HCB-PG.zip
(172.75 KiB) Downloaded 58 times
Error message_2.png (320.97 KiB) Viewed 488 times
Post by kesavapraba » Wed Sep 25, 2024 11:13 am
Hi, Your model works fine on my end. I use recent version of STKO v4.0 released yesterday. Please check the attached file. Use parallel version of OpenSees
(181.06 KiB) Downloaded 65 times
