Can you please clarify what is going on and how to fix it. It seems like a bug. Thank you.Serialization exception: Cannot open file: "D:/Dropbox (CSU Fullerton)/Research/SSI/OpenSees models/3D 240x240x30-STKO/Nonlinear_Models/SSI_NL_Struct_CONC_ALL_NO_INTERFACE_Found_2_W_Slab_PtGload_Cols_4_2_Dmp_Rgn_Cntct_Pen_10e6_Pen_Anal_1e12_Nu_03_Grav_GM.scd".
File: "..\..\MpcCore\MpcCoreApp\Serialization\MpcCaeDocumentSerializer.cpp
Function: load (Line: 45)
error #0 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5F.c in H5Fopen(): line 793.
class: HDF5
major: File accessibility
minor: Unable to open file
error #1 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL_file_open(): line 3500.
class: HDF5
major: Virtual Object Layer
minor: Can't open object
error #2 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL__file_open(): line 3465.
class: HDF5
error #3 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLnative_file.c in H5VL__native_file_open(): line 100.
class: HDF5
error #4 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Fint.c in H5F_open(): line 1564.
class: HDF5
error #5 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5FD.c in H5FD_open(): line 741.
class: HDF5
major: Virtual File Layer
minor: Unable to initialize object
error #6 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5FDsec2.c in H5FD_sec2_open(): line 346.
class: HDF5
An error occurred while loading the specified file. A default file will be created.
Cannot open old models
Hello, I am trying to open one of my old models and I get the following error. The model might have been moved from one folder to another.
Re: Cannot open old models
It's the HDF5 library that is complaining about the File Accessibility.
There could be many reasons for that.
- The file does not exist
- The file is open by another process that is preventing STKO from opening it
- You don't have read access to the Dropbox folder (I don't think this is the case...)
When I copy it to Desktop it works. I am confused because all my files are in Dropbox and I used to be able to open this file from Dropbox. The only thing that changed is that I reorganized some folders and moved this file from one Dropbox folder to thr other. It seems like there is nothing we can do to address this. Thanks for clarifying.
I don't know if in the new folder, you have generic accessibility restrictions.
Try to open the *.SCD file with the python library h5py (which used HDF5) and let's see if it also shows the same error
