MPCRecorder Error: cannot write model
amb_1
Post by amb_1 » Thu Jun 29, 2023 9:56 am
Dear STKO Team:
Thanks for your help, I have encountered a new problem with the MPCRecorder command, when I use the default way it works fine and records the whole model, however, when I just want to record the core area, it does not work. I checked the relevant information in the forum "viewtopic.php?f=29&t=1609&p=2064&hilit= ... ions#p2064" and the problem may arise from using MoelSubset, however For complex models, MoelSubset, is a must. I have provided a preliminary model, can you give me some advice?
Sincerely
AMbcha
Re: MPCRecorder Error: cannot write model
Post by STKO Team » Fri Sep 08, 2023 10:23 am
You have to add the model subset before the region, otherwise OpenSees will put nothing in that region if the elements are not yet created
