EQUIVALENT FRAME MODEL
Chaymaa
Post by Chaymaa » Fri May 27, 2022 2:12 am
Hi STKO team,
Is there any webinar that explains the equivalent frame modeling, in the case of a masonry structure ? I found this video (https://www.youtube.com/watch?v=TovQNKvmoqQ) on your youtube channel, but it's a little bit complicated and isn't commented.
I'm trying to model a masonry wall, but I'm facing some issues. I guess it has a link with way I modeled the wall.
Many thanks for your support.
Re: EQUIVALENT FRAME MODEL
Post by STKO Team » Fri May 27, 2022 9:08 am
The last webinar in the getting started series
3D Frame Structures (Part 3) - Masonry: EFM of trilite and masonry walls
https://asdeasoft.net/?get-started-webinars
Chaymaa
Post by Chaymaa » Fri Jun 03, 2022 5:52 pm
Hi STKO team,
I am trying to model a wall without openings. Should I add between the piers some rigid zones as what you did in this video (https://www.youtube.com/watch?v=TovQNKvmoqQ&t=833s) ? And why you added them in that case ?
Thank you for the support !
Post by STKO Team » Wed Jun 08, 2022 8:38 am
It depends on how much they are connected in reality. It's up to you
