Attached please find the RC frame STKO file. I successfully assigned each and everything and finally meshed it but while running the analysis the error in the subject cited above is appearing.
Would you please be so kind to fix the issue.
Thanking you in anticipation.
Nisar
Local Variable "node" referenced before assignment
nisaralikhan
- Bare Frame.rar
- (106.17 KiB) Downloaded 185 times
Re: Local Variable "node" referenced before assignment
Dear User,
the Selection Set for the control node was empty.
You need to add a vertex to that selection set, otherwise the DisplacementControl method will not find the control node. Here is the fixed model
