Local Variable "node" referenced before assignment
nisaralikhan
Post by nisaralikhan » Fri Sep 25, 2020 10:40 pm
Attached please find the RC frame STKO file. I successfully assigned each and everything and finally meshed it but while running the analysis the error in the subject cited above is appearing.
Would you please be so kind to fix the issue.
Thanking you in anticipation.
Nisar
Bare Frame.rar
(106.17 KiB) Downloaded 185 times
Re: Local Variable "node" referenced before assignment
Post by STKO Team » Mon Sep 28, 2020 10:13 am
Dear User,
the Selection Set for the control node was empty.
You need to add a vertex to that selection set, otherwise the DisplacementControl method will not find the control node.
Senza nome.png (464.82 KiB) Viewed 1461 times
Here is the fixed model
Bare Frame.zip
(164.51 KiB) Downloaded 243 times
