I try to imitate the pull_out example (see pull_out_imitate.scd) . But, I can not obtain same meshing (see pull_out_imitate_error,jpg) as in the orginal one (see pull_out_imitate_orginal.jpg). Which step do I skip at?
Meshing problem
Meshing problem
- pull_out_orginal.JPG (57.45 KiB) Viewed 316 times
- pull_out_imitate_error.JPG (22.12 KiB) Viewed 316 times
- pull_out_imitate.rar
- (88.96 KiB) Downloaded 68 times
Best wishings,
Re: Meshing problem
Hi, This happens because the meshing seed is set that meshing line exactly coincides with the beam element. So, try with a reduced mesh size, for example, go to "Global seed" under meshing tab and put 0.8 by selecting "Uniform by size".
