Meshing problem
MusZip
Meshing problem
Post by MusZip » Wed Oct 09, 2024 8:49 am
I try to imitate the pull_out example (see pull_out_imitate.scd) . But, I can not obtain same meshing (see pull_out_imitate_error,jpg) as in the orginal one (see pull_out_imitate_orginal.jpg). Which step do I skip at?
pull_out_imitate.rar
(88.96 KiB) Downloaded 68 times
Best wishings,
Re: Meshing problem
Post by kesavapraba » Wed Oct 09, 2024 11:10 am
Hi, This happens because the meshing seed is set that meshing line exactly coincides with the beam element. So, try with a reduced mesh size, for example, go to "Global seed" under meshing tab and put 0.8 by selecting "Uniform by size".
