I try to model a simple beam using "Fiber section" with circular shape. There is a posiblity of defining a material as either "nd" or "uniaxal". If I define the fiber section using "uniaxial material", the material command under the command "Fiber section" is "activated", otherwise "inactive". At this time, I get a warning error as "physical property must be: 'materials.nd' and not: 'materials.uniaxial'.
What must I do in order to activate the material button under the command "Fiber section" for nD material?
Circular Fiber Usage
- Lesson5_4_ASDEAEmbedeNodeElement_deneme1_error_FiberUsing.JPG (204.42 KiB) Viewed 570 times
Best wishings,
Re: Circular Fiber Usage
Hi, you can only assign uniaxial material to fiber sections, so define a uniaxial material before defining the fiber section, the uniaxial material can be populated in the fiber section window. Please read the OpenSees documentation, as seen in the attached figure.
- fiber.png (120.85 KiB) Viewed 566 times
Dear Kesavapraba,
Yes you are certainly right. In fact, I am agree with you. But, as I see it you in the perevios message, I get an warning error when I define the fiber section using the property of "uniaxial material" (see Lesson5_4_ASDEAEmbedeNodeElement_deneme1_error_FiberUsing2.jpg).
I hope to convey it you.
- Lesson5_4_ASDEAEmbedeNodeElement_deneme1_error_FiberUsing2.JPG (110.35 KiB) Viewed 561 times
Best wishings,
Hi, This error should be for solid but not from fiber. because I don't see any nD material created in physical properties for solid element.
