Boolean operations
Lei Lei
Re: Boolean operations
Post by Lei Lei » Thu Mar 07, 2024 1:46 am
Thanks for your reply!
kesavapraba wrote:
Wed Mar 06, 2024 3:21 pm
Hi, You can handle the individual geometry after the explode command executed multiple times. So, the extra surfaces can be deleted.
Actually, solid A or solid B will explode into planes. What I want to do is that union solid A and solid B without a public surface.
Similarly, can I merge two line segments into a straight line without keeping a common endpoint, and two faces into a single face without keeping a common line?
By the way, as for solid B which has a redundant line C, is there any way to delete the line C without destroying solid B?
Post by kesavapraba » Thu Mar 07, 2024 10:46 am
Hello, using the built-in CAE commands in STKO, achieving what you requested is not possible.
Lei Lei
Post by Lei Lei » Fri Mar 08, 2024 6:27 am
All right, thanks for your kindness and patience!
Post by kesavapraba » Fri Mar 08, 2024 6:31 am
You are welcome.
