Analysis did not converge
CesarDavid
Post by CesarDavid » Wed Jan 17, 2024 2:36 pm
Any help with this model convergence.
Modelo_Loa_Tarque_Condori_V3.zip
(175.43 KiB) Downloaded 291 times
Re: Analysis did not converge
Post by STKO Team » Wed Jan 17, 2024 3:55 pm
Merge your model. All faces are separated
CesarDavid
Post by CesarDavid » Wed Jan 17, 2024 4:22 pm
Thank you very much. I did, but still no convergence.
Post by kesavapraba » Thu Jan 18, 2024 7:55 am
Hi, Please note the following changes that I made to your model, and it now runs smoothly.
1] It seems that pushover load definition has some issue. Time series (ciclica) for the pushover displacement already included a comparable displacement (~28 mm), however the spPrescribed load in the condition again multiplies it with -31. You are multiplying the actual displacement by 31! So, I changed it to -1. You can see the maximum displacement as around 30 from the experimental background curve.
2] Refine the mesh to improve the accuracy
3] Analysis settings (pushover): Increase the numIncr to atleast 5000 since the cyclic loading has many loops, hence increasing numIncr can help achieving good match between the experimental and numerical prediction.
(163.66 KiB) Downloaded 304 times
CesarDavid
Post by CesarDavid » Thu Jan 18, 2024 1:22 pm
I really apreciate your help. Thanks
Post by kesavapraba » Thu Jan 18, 2024 3:19 pm
You are welcome
Gabriele.Neri
Post by Gabriele.Neri » Wed Mar 13, 2024 7:25 pm
Dear stko team,
I'm trying to do a parametric analysis, but I have some issues with the convergence.
I've tried to use different system solvers (Mumps, UmfPack), I've tried to increase the numIncr, without getting any results.. Can you help me?
I attached the error, the warning and the file I'm testing on.
Concerning the parametric analysis, the steps are the following:
- I created TCL files with the Write Input File command
- I opened a command shell in the directory in which I generated the TCL files
_I launched OpenSees with the number of processors = number of parameters, that are 30 in this case
(C:\OpenSees-Solvers\openseesmp.bat main.tcl 30)
Thanks in advance
Warning parametric analysis.png (14.91 KiB) Viewed 2748 times
Error parametric analysis.png (23.8 KiB) Viewed 2748 times
file 0.4g.zip
(2.18 MiB) Downloaded 235 times
Post by kesavapraba » Thu Mar 14, 2024 2:58 pm
Hi, the issue is with forceBeamColumn element, it is not able to find force/displacement compatibility. I checked the BeamSectionProperty, you have used hinge option with nonlinear fiber model for the middle of the beam or column elements. I suggest this is not necessary unless you go for finite plastic hinge length model at the ends of the beam-column elements. Hence, I modified it to StandardIntergration type with 5 integration points, as you see in the attached figure. Now, the analysis converges.
TimeHistory Gabriele_rev.zip
(179.79 KiB) Downloaded 235 times
Gabriele.Neri
Post by Gabriele.Neri » Thu Mar 14, 2024 3:37 pm
kesavapraba wrote: ↑
Meanwhile thanks for teh support!
You are right, I set hinge option both for beam and column elements because I need to consider non linearity for the entire length of beam-column elements in the model.
Thanks in advance
Post by kesavapraba » Fri Mar 15, 2024 11:41 am
Ok, Yes, you can do it without hinge option as I suggested in my previous post. Thank you.
