A huge vertical acceleration
[email protected]
Post by [email protected] » Thu Nov 16, 2023 4:16 pm
I followed the example of seismic analysis of a 2D soil column with WaveLet and dashpot. The soil material was linear elastic. When I used the “quadrilateral_elements.quad” everything went on right, the results are as following figures:
But when I change the element type to “up_elements.quadUP” there was a huge vertical acceleration:
I have tried many means but these large vertical acceleration still exists. Would anyone please give me some guide? Many thanks!
(notice that I need to used this quadUP element and apply the self weight using the “Optional parameters” of b2 so as to build the correct pore pressure. If I can run with PDMY02 material is better.)
Soil_Column_Quad_UP_Dashpot.rar
(131.56 KiB) Downloaded 224 times
Re: A huge vertical acceleration
Post by kesavapraba » Fri Nov 17, 2023 10:46 am
Hi, this occurrence may be attributed to improper element properties of the quadUP, specifically pertaining to permeability parameters. I recommend a thorough review and verification of these parameters to ensure their accuracy.
Post by STKO Team » Thu Nov 23, 2023 1:59 pm
Try this with the new absorbing boundary elements.
Note: here the time series for the base action should be exactly the velocity
www.zip
(233.8 KiB) Downloaded 310 times
