How the hysteresis curve of the displacement control obtains the value of the corresponding force and the change process
[email protected]
Post by [email protected] » Mon Sep 04, 2023 10:45 am
Dear STKO team, during the analysis, I set up two analyses, the first time I applied the column end axial force, the second time I wanted to get the hysteresis curve through horizontal displacement control, but I couldn't run the second analysis, can you tell me what to do?
9-4.rar
(119.27 KiB) Downloaded 146 times
Last edited by [email protected] on Tue Sep 05, 2023 2:42 am, edited 1 time in total.
[email protected]
Re: Please help me check where this error below is
Post by [email protected] » Tue Sep 05, 2023 2:40 am
Dear STKO, I have found a solution to this problem, now I have a new question, I applied a force P in the X direction at point CN1(13), and at the same time I want to use the displacement control for hysteresis, and finally get the hysteresis curve, can you tell me how to get the change curve of P in STKO?
Re: How the hysteresis curve of the displacement control obtains the value of the corresponding force and the change pro
Post by STKO Team » Fri Sep 08, 2023 10:47 am
You can use a Displacement-Control integrator.
There, instead of using a Target displacement, you can provide a Path time series where you have the displacement cycles
