Error: con't find option attribute
[email protected]
Post by [email protected] » Sun Jun 04, 2023 3:07 am
Dear STKO:
I built a node model to get its hysteresis curve. But there was an error while running, I just started using STKO, so I can't find the cause of the error, can you check it for me? Thank you!
001.rar
(140.59 KiB) Downloaded 194 times
Re: Error: con't find option attribute
Post by STKO Team » Mon Jun 05, 2023 2:32 pm
It's because you assigned a fiber section (property 7) directly to a beam element, while you should put it inside a beamSectionProperty (as you did for other properties, for example, property 15)
[email protected]
Post by [email protected] » Fri Jul 14, 2023 8:56 am
Thank you very much, my problem was solved.
Post by STKO Team » Mon Jul 17, 2023 8:43 am
