Dear STKO:
I built a node model to get its hysteresis curve. But there was an error while running, I just started using STKO, so I can't find the cause of the error, can you check it for me? Thank you!
Error: con't find option attribute
[email protected]
- 001.rar
- (140.59 KiB) Downloaded 194 times
Re: Error: con't find option attribute
It's because you assigned a fiber section (property 7) directly to a beam element, while you should put it inside a beamSectionProperty (as you did for other properties, for example, property 15)
[email protected]
Thank you very much, my problem was solved.
