Dear Team,
I have a small query if I need to add the elements to the already existing model which has been already analyzed like infill to the RC bare frame building. Do I need to explode the existing model and add infills and then again make wire. What is the right procedure? Because It is very hard to make again the model from the beginning.
Zeeshan Bhat
Adding element to already existing model
Zeeshanbhat
Re: Adding element to already existing model
Dear Zeeshan Bhat,
No you do not need to explode your geometry, just select the added elements and the wire already created and repeat the Make Wire command.
Enjoy your modeling
Enjoy your modeling
Zeeshanbhat
In term of removing some elements from the existing model.
Do I need to explore and do everything again?
Thank you,
Buu
Thank you,
Buu
No, you can just use the sub-selection feature, select the sub-parts of the geometry you want to remove, and press DEL
