Adding element to already existing model
Zeeshanbhat
Post by Zeeshanbhat » Mon Feb 22, 2021 12:23 pm
Dear Team,
I have a small query if I need to add the elements to the already existing model which has been already analyzed like infill to the RC bare frame building. Do I need to explode the existing model and add infills and then again make wire. What is the right procedure? Because It is very hard to make again the model from the beginning.
Zeeshan Bhat
Re: Adding element to already existing model
Post by marafini.f » Mon Feb 22, 2021 1:50 pm
Dear Zeeshan Bhat,
No you do not need to explode your geometry, just select the added elements and the wire already created and repeat the Make Wire command.
Enjoy your modeling
Zeeshanbhat
Post by Zeeshanbhat » Tue Feb 23, 2021 7:16 am
BuuNguyen
Contact:
Post by BuuNguyen » Thu May 19, 2022 5:34 am
In term of removing some elements from the existing model.
Do I need to explore and do everything again?
Thank you,
Buu
Post by STKO Team » Thu May 19, 2022 10:42 am
No, you can just use the sub-selection feature, select the sub-parts of the geometry you want to remove, and press DEL
