Dear stko team,
I am continuously recieveing the error as shown in the screenshot. I checked all bars and concrete sections and all the element and physical properties are assigned properly.
Can you plz mention the reason for the error?
The model is also attached herewith.
THanks
Issue in analysis
Issue in analysis
- Ghob 3d solid.zip
- (1.06 MiB) Downloaded 197 times
- 3d ghob.png (128.07 KiB) Viewed 2250 times
Re: Issue in analysis
You are using a dispBeamElement while the material is for truss.
You can now either change the element property to truss, or create a fiber section with your steel materials, and the associated beamSectionProperty and use them as physical properties.
thank you
regards
regards
