Issue in analysis
Asad005
Issue in analysis
Post by Asad005 » Tue Mar 02, 2021 5:40 am
Dear stko team,
I am continuously recieveing the error as shown in the screenshot. I checked all bars and concrete sections and all the element and physical properties are assigned properly.
Can you plz mention the reason for the error?
The model is also attached herewith.
THanks
Ghob 3d solid.zip
(1.06 MiB) Downloaded 197 times
3d ghob.png (128.07 KiB) Viewed 2251 times
Re: Issue in analysis
Post by STKO Team » Tue Mar 02, 2021 9:52 am
You are using a dispBeamElement while the material is for truss.
You can now either change the element property to truss, or create a fiber section with your steel materials, and the associated beamSectionProperty and use them as physical properties.
Asad005
Post by Asad005 » Tue Mar 02, 2021 1:59 pm
thank you
regards
Post by STKO Team » Wed Mar 03, 2021 8:47 am
You're welcome!
