Fiber Section Patch
davidcasas25
Fiber Section Patch
Post by davidcasas25 » Fri Jul 24, 2020 10:38 pm
Hello, I would like to know if there is a way for creating patch on fiber sections in STKO. I´m trying to model C shaped walls with fibers.
HannahCartwright
Re: Fiber Section Patch
Post by HannahCartwright » Mon Jul 27, 2020 5:40 am
Hi David, Great question!
The patch command is an OpenSees command to generate a set of fibers in a quad-like shape. In STKO you can do the same by creating a new Physical Property -> section -> Fiber (see the attached images).
I hope that helps!
Let us know if you have any further questions about the process.
image (16).png (407.97 KiB) Viewed 2631 times
image (17).png (939.89 KiB) Viewed 2631 times
