ISSUE RIGID DIAPHRAGM MASONRY SHELL
Dear forum members,
I am modelling masonry arcades using shell elements. I have used a rigid diaphragm constraint to simulate the effect of the roof on top of the arcades being rigid. I have constrained the master node by locking Uz, Rx and Ry. After that, I set up the modal analysis steps, requesting 6 modes of vibration.
However, when I submit the analysis, a warning message appears indicating that 'MumpsParallelSolver::solve(void) - Error -3 returned in substitution dmumps()'. However, the results I obtained only show one local mode, which does not make sense. I have tried other solvers and elastic-plastic materials, and either the analysis does not run or the results are incorrect.
I would be grateful if someone could point out where the error is. Please find attached a simplified version of the model that I am trying to run.
I look forward to receiving your feedback and thank you in advance.
- Mezq_3arcadetest_diap_MODAL.rar
- (314.8 KiB) Downloaded 9 times
Re: ISSUE RIGID DIAPHRAGM MASONRY SHELL
I don't see any error, try to update your opensees and/or STKO.
Hi STKO Team,
Thanks for answering so fast.
Thats weird. When I run the analysis, I get the Mumps error and the analysis continues until I get the results. However, as you can see in the screenshot, there is definetly a problem with the solver. Also, the period is super high.
I have STKO 4.1.0 and Opensees 3.7.2 downloaded from prof Nicola Tarque's.
- Captura.JPG (197.12 KiB) Viewed 547 times
That's weird... I tested it with those exect versions and it works fine on my side.
1) Make sure to you have the correct latest versions: just re-download them to be sure
2) maker sure the file you sent here to the forum is the one you are testing
I have reinstalled both STKO and OpenSees using the 3.7.2 file from here: https://www.researchgate.net/publicatio ... ltext=true.
I have run the same file uploaded.
I get the same results...
I am not sure what it might be happening here.
I run the file from here using shell elements and rigid diap and I dont have any problems: viewtopic.php?p=10658&hilit=rigid+diaf#p10658
I have changed the element property from ASDShellT3 to ShellNLDKGT and I get your moral shapes.
I just tested with those exact versions and I don't see any problem
Sorry, I have tried to run the model in 3 different computers and it does not run correctly. We have checked that both STKO and OpenSees are updated.
- Captura.JPG (270.19 KiB) Viewed 387 times
But from the output of your commandline it seems you are running an eigenvalue analysis with more than 1 processor.
Is it true?
In that case, OpenSees eigen command can only run with 1 processor
Is it true?
The model (uploaded at the beginning of this thread) has one partition. I run the analysis with openseesmp. I havent had problems with this. Actually, if I change the type of element to ShellDKGT (for example), the model works.
