OpenSees Solver 3.7.2
Zouatine
Post by Zouatine » Thu Sep 18, 2025 9:02 am
Dear Stko Team ,
I wanted to kindly ask about your thoughts for the following issue.
I have downloaded the new OpenSeesSolver (Version 3.7.2) from the website :
https://www.researchgate.net/publicatio ... r_OpenSees
I have created a simple model for 3D analysis soil, when i run it with the opnseesmp 3.4.0 (old file) it work fine , but i use the opensees solver for parallel analysis from 3.7.2 , i end to the following error:
I tried several other models which were running correctly in the old solver but with new solver i am having the above issue.
Re: OpenSees Solver 3.7.2
Post by STKO Team » Mon Sep 22, 2025 8:48 am
Can you share the STKO model?
Without further information it's hard to tell
Zouatine
Post by Zouatine » Mon Sep 22, 2025 10:48 am
Thank you for your response,
Sure here are some models, which do run for me when i use the 3.4 version, these models I have downloaded them from the forum , which were posted by you :
nl_abs.zip
(251.17 KiB) Downloaded 89 times
soil small.zip
(495.64 KiB) Downloaded 99 times
Thank you,
Post by STKO Team » Wed Sep 24, 2025 10:02 am
Both analyses are running on my side.
Do you have the same issue also with other models using openseesmp from the new version?
Zouatine
Post by Zouatine » Wed Sep 24, 2025 10:51 am
Yes , i do have the same issue. As i said in my previous post , the models were running for the old versions but not with the new one.
Post by STKO Team » Thu Sep 25, 2025 7:47 am
If the issue is with the new installation and for all opensees models, it means there is something wrong with your opensees installation.
How did you install the new version?
Are you sure your firewall and/or antivirus is blocking the mpiexec executable in your OpenSees installation directory (C:\OpenSees-Solvers\oneapi)?
