STKO’s Domain Reduction Method
Posted: Tue Aug 05, 2025 6:59 am
Dear All,
I am currently working on implementing the Domain Reduction Method (DRM) available in STKO, as demonstrated in the webinar. This approach requires an H5DRM file generated using the ShakerMaker module, which provides a set of input motions to excite the model.
I have attempted multiple times to install ShakerMaker within an Anaconda-created environment. I also tried running the code in Visual Studio Code, following the installation instructions provided on GitLab. However, I consistently encounter issues when executing the command:
sudo python setup.py install
The error appears to be related to the Fortran compiler. Since ShakerMaker contains components written in Fortran, it seems these parts are not functioning correctly. When I run the installation command, I receive the following error:
Would you assist me to resolve this issue ?
+ Can i use the DRM in STKO with another input type ? i mean like using a defined normal time serie ?
Thank you,
Thank you,
