Page 1 of 2
Cannot find pdm.dll
Posted: Tue Apr 15, 2025 5:58 am
by HBC_FEM
Hallo,
I tried to run a file and received an error message saying that the pdm.dll file could not be found. However, the file is located in the folder C:\OpenSees-Solver\OpenSees3.7.0\plugins. Does anyone know what this problem is?
Re: Cannot find pdm.dll
Posted: Tue Apr 22, 2025 7:39 am
If the installation of the OpenSees-Solvers is correct, and you are running it one of the batch files (opensees.bat, openseesp.bat or openseesmp.bat) OpenSees should find that DLL
Posted: Tue Apr 22, 2025 9:04 am
by HBC_FEM
thanks, it seems to work.
But now i have another error message (see attachment).
You may help one more time.
regards.
Posted: Wed Apr 23, 2025 8:26 am
Put the DamageTC3D material into a PlateFiber ND material wrapper, and use that in the layered section
Posted: Wed Apr 23, 2025 9:25 am
by HBC_FEM
that was already done.
Beton material was the TC3D and Beton ext was the plate fiber material.
But it seems that there is a problem with the rebar fiber. I am not sure.
Posted: Wed Apr 23, 2025 12:59 pm
sorry but from the image I cannot see the material types.
Can you share the model?
Posted: Thu Apr 24, 2025 6:22 am
by HBC_FEM
i can send the .scd file via E-Mail at
[email protected] if it is possible.
Posted: Thu Apr 24, 2025 8:07 am
You can attach it here after zipping it
Posted: Thu Apr 24, 2025 8:17 am
by HBC_FEM
here is the file.
Posted: Mon Apr 28, 2025 8:15 am
You have to use PlateRebar for shells, not PlaneStressRebars (which is for 2D plane-stress analysis):
- shell_rebar.png (31.48 KiB) Viewed 2327 times
Then you will find an error about the compressive fracture energy being too small...
