ERROR IN THE RUN SOLVER: "NO SUCH FILE OR DIRECTORY"
Giorgio Serra
Post by Giorgio Serra » Thu Mar 27, 2025 10:17 am
DEAR STKO,
The main object of the test is bent GFRP stirrups loaded in tension until failure occurs at the bend. Below I have reported a conceptual scheme of the specimen. After defining the entire model in the STKO preprocessor, the following message appears in the prompt: "no such file or directory". I would like to understand what the error could be due to.
STAFFA_3D_ver1.zip
This is the incriminated file
(1.26 MiB) Downloaded 145 times
Re: ERROR IN THE RUN SOLVER: "NO SUCH FILE OR DIRECTORY"
Post by STKO Team » Tue Apr 01, 2025 7:30 am
I don't see that error, are you sure you attached the right file?
Anyway, there are some mistakes in the attached file.
No fix on the global Y direction, better to use NormDispIncr due to penalty based constraints such as EmbeddedNodeElements, use more initial time steps and an adaptive time step algorithm to pass convergence issue.
Giorgio Serra
Post by Giorgio Serra » Tue Apr 01, 2025 10:30 am
Hi
yes i'm sure, it is the right file. The message it's the seguent:
screenshot of the RunSolver
Immagine 2025-03-27 105228.png (25.24 KiB) Viewed 2528 times
Post by STKO Team » Wed Apr 02, 2025 7:55 am
You didn't set up the solver command properly.
maybe you forgot the #1 keyword that STKO uses as a placeholder for the tcl file name (and in your case is empty):
Giorgio Serra
Post by Giorgio Serra » Tue Apr 08, 2025 7:34 am
Thanks for the support, now it works!
Post by STKO Team » Thu Apr 10, 2025 8:05 am
