Material stress is failed to be tracked
Posted: Wed Feb 19, 2025 11:59 am
I am the beginner of Opensees based STKO.
I am trying to practice the soil-pile interaction modeling in the advanced e learning courses (https://asdea.eu/software/advanced-e-le ... urses/#022) using the documents provided by Dr.Massimo.
I found that although material.stress was set to be recorded in the SKTO pre-process, the stress is failed to be shown by the post processor. I cannot find it in surface color map or fiber color map (opensees 3.7.0). I use another compter to test with different Opensees version (3.4.0). The same thing happened.
I am wondering if it is because the incompatible issue between the old version documents and the new version of STKO/opensses? I atttach .scd file and corresponding mcpo file for you to check
Best regards,
Jiangtao
Best regards,
Jiangtao
