Hi, I'm creating a stko model of a reinforced concrete frame in which the infill is modeled through 2 pairs of struts. The central part of the struts is made up of a fiber section composed of 120 fibers and therefore 60 different fiber materials. To optimize the fiber material insertion procedure I wanted to write a script that allows me to automatically parameterize the parameters of the fiber materials of the strut by directly taking the values from an excel sheet with the data inside.
The problem is that after running the script it gives me this error: no module named 'openpyxl' as reported in the following screens.
How can I solve it? Is the script correct to be able to parameterize the fiber material?
Material parameterization
giulio.zanellato
- F-02.12.24_PO_IP_InfilledFrame.zip
- (106.23 MiB) Downloaded 111 times
- Error openpyxl.jpg (78.46 KiB) Viewed 1926 times
- Screen.jpg (233.71 KiB) Viewed 1926 times
Re: Material parameterization
It's because STKO uses its own embedded python interpreter, and openpyxl is not in C:\Program Files\STKO\python_packages
You have 3 options:
You have 3 options:
- copy the openpyxl folder from your python lib directory to the python_packages (but you will have to do it everytime you install a new STKO version)
- Do this before importing
(but it's dangerous, because now STKO will see all the libs in your python, and some of them may conflict with those used by STKO).
import sys sys.path.append('C:/Python310/Lib/site-packages') import openpyxl - Mix the 2 previous approaches, copy openpyxl out of Lib/site-packages and out of STKO install folder (say for example in C:\MyCustomPackages, now use sys.path.append('C:\MyCustomPackages')
giulio.zanellato
ok thank you very much I solved it. Now I'm running the script and I get these debugs that I put. How can I fix it so that the materials are created? I tried more functions but unfortunately I'm not solving any of them.
Terminal
Inizio esecuzione script...
Documento STKO caricato.
Percorso file Excel: D:\Giulio\F\02.12.24_PO_IP_InfilledFrame\LibreriaSezione_fibreTamponamenti.xlsx
File Excel trovato.
Caricamento del file Excel...
Caricamento del file Excel completato.
Sto leggendo il foglio: F (Minotto 2020)
Leggendo riga 6...
Creando materiale Hysteretic con ID 101...
Errore nella creazione del materiale ID 101: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 7...
Creando materiale Hysteretic con ID 102...
Errore nella creazione del materiale ID 102: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 8...
Creando materiale Hysteretic con ID 103...
Errore nella creazione del materiale ID 103: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 9...
Creando materiale Hysteretic con ID 104...
Errore nella creazione del materiale ID 104: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 10...
Creando materiale Hysteretic con ID 105...
Errore nella creazione del materiale ID 105: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 11...
Creando materiale Hysteretic con ID 106...
Errore nella creazione del materiale ID 106: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 12...
Creando materiale Hysteretic con ID 107...
Errore nella creazione del materiale ID 107: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 13...
Creando materiale Hysteretic con ID 108...
Errore nella creazione del materiale ID 108: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 14...
Creando materiale Hysteretic con ID 109...
Errore nella creazione del materiale ID 109: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 15...
Creando materiale Hysteretic con ID 110...
Errore nella creazione del materiale ID 110: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 16...
Creando materiale Hysteretic con ID 111...
Errore nella creazione del materiale ID 111: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 17...
Creando materiale Hysteretic con ID 112...
Errore nella creazione del materiale ID 112: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 18...
Creando materiale Hysteretic con ID 113...
Errore nella creazione del materiale ID 113: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 19...
Creando materiale Hysteretic con ID 114...
Errore nella creazione del materiale ID 114: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 20...
Creando materiale Hysteretic con ID 115...
Errore nella creazione del materiale ID 115: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 21...
Creando materiale Hysteretic con ID 116...
Errore nella creazione del materiale ID 116: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 22...
Creando materiale Hysteretic con ID 117...
Errore nella creazione del materiale ID 117: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 23...
Creando materiale Hysteretic con ID 118...
Errore nella creazione del materiale ID 118: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 24...
Creando materiale Hysteretic con ID 119...
Errore nella creazione del materiale ID 119: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 25...
Creando materiale Hysteretic con ID 120...
Errore nella creazione del materiale ID 120: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 26...
Creando materiale Hysteretic con ID 121...
Errore nella creazione del materiale ID 121: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 27...
Creando materiale Hysteretic con ID 122...
Errore nella creazione del materiale ID 122: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 28...
Creando materiale Hysteretic con ID 123...
Errore nella creazione del materiale ID 123: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 29...
Creando materiale Hysteretic con ID 124...
Errore nella creazione del materiale ID 124: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 30...
Creando materiale Hysteretic con ID 125...
Errore nella creazione del materiale ID 125: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 31...
Creando materiale Hysteretic con ID 126...
Errore nella creazione del materiale ID 126: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 32...
Creando materiale Hysteretic con ID 127...
Errore nella creazione del materiale ID 127: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 33...
Creando materiale Hysteretic con ID 128...
Errore nella creazione del materiale ID 128: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 34...
Creando materiale Hysteretic con ID 129...
Errore nella creazione del materiale ID 129: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 35...
Creando materiale Hysteretic con ID 130...
Errore nella creazione del materiale ID 130: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 36...
Creando materiale Hysteretic con ID 131...
Errore nella creazione del materiale ID 131: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 37...
Creando materiale Hysteretic con ID 132...
Errore nella creazione del materiale ID 132: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 38...
Creando materiale Hysteretic con ID 133...
Errore nella creazione del materiale ID 133: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 39...
Creando materiale Hysteretic con ID 134...
Errore nella creazione del materiale ID 134: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 40...
Creando materiale Hysteretic con ID 135...
Errore nella creazione del materiale ID 135: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 41...
Creando materiale Hysteretic con ID 136...
Errore nella creazione del materiale ID 136: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 42...
Creando materiale Hysteretic con ID 137...
Errore nella creazione del materiale ID 137: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 43...
Creando materiale Hysteretic con ID 138...
Errore nella creazione del materiale ID 138: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 44...
Creando materiale Hysteretic con ID 139...
Errore nella creazione del materiale ID 139: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 45...
Creando materiale Hysteretic con ID 140...
Errore nella creazione del materiale ID 140: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 46...
Creando materiale Hysteretic con ID 141...
Errore nella creazione del materiale ID 141: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 47...
Creando materiale Hysteretic con ID 142...
Errore nella creazione del materiale ID 142: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 48...
Creando materiale Hysteretic con ID 143...
Errore nella creazione del materiale ID 143: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 49...
Creando materiale Hysteretic con ID 144...
Errore nella creazione del materiale ID 144: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 50...
Creando materiale Hysteretic con ID 145...
Errore nella creazione del materiale ID 145: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 51...
Creando materiale Hysteretic con ID 146...
Errore nella creazione del materiale ID 146: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 52...
Creando materiale Hysteretic con ID 147...
Errore nella creazione del materiale ID 147: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 53...
Creando materiale Hysteretic con ID 148...
Errore nella creazione del materiale ID 148: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 54...
Creando materiale Hysteretic con ID 149...
Errore nella creazione del materiale ID 149: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 55...
Creando materiale Hysteretic con ID 150...
Errore nella creazione del materiale ID 150: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 56...
Creando materiale Hysteretic con ID 151...
Errore nella creazione del materiale ID 151: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 57...
Creando materiale Hysteretic con ID 152...
Errore nella creazione del materiale ID 152: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 58...
Creando materiale Hysteretic con ID 153...
Errore nella creazione del materiale ID 153: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 59...
Creando materiale Hysteretic con ID 154...
Errore nella creazione del materiale ID 154: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 60...
Creando materiale Hysteretic con ID 155...
Errore nella creazione del materiale ID 155: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 61...
Creando materiale Hysteretic con ID 156...
Errore nella creazione del materiale ID 156: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 62...
Creando materiale Hysteretic con ID 157...
Errore nella creazione del materiale ID 157: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 63...
Creando materiale Hysteretic con ID 158...
Errore nella creazione del materiale ID 158: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 64...
Creando materiale Hysteretic con ID 159...
Errore nella creazione del materiale ID 159: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 65...
Creando materiale Hysteretic con ID 160...
Errore nella creazione del materiale ID 160: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 66...
Creando materiale Hysteretic con ID 161...
Errore nella creazione del materiale ID 161: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 67...
Creando materiale Hysteretic con ID 162...
Errore nella creazione del materiale ID 162: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 68...
Creando materiale Hysteretic con ID 163...
Errore nella creazione del materiale ID 163: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 69...
Creando materiale Hysteretic con ID 164...
Errore nella creazione del materiale ID 164: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 70...
Creando materiale Hysteretic con ID 165...
Errore nella creazione del materiale ID 165: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 71...
Creando materiale Hysteretic con ID 166...
Errore nella creazione del materiale ID 166: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 72...
Creando materiale Hysteretic con ID 167...
Errore nella creazione del materiale ID 167: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 73...
Creando materiale Hysteretic con ID 168...
Errore nella creazione del materiale ID 168: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 74...
Creando materiale Hysteretic con ID 169...
Errore nella creazione del materiale ID 169: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 75...
Creando materiale Hysteretic con ID 170...
Errore nella creazione del materiale ID 170: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 76...
Creando materiale Hysteretic con ID 171...
Errore nella creazione del materiale ID 171: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 77...
Creando materiale Hysteretic con ID 172...
Errore nella creazione del materiale ID 172: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 78...
Creando materiale Hysteretic con ID 173...
Errore nella creazione del materiale ID 173: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 79...
Creando materiale Hysteretic con ID 174...
Errore nella creazione del materiale ID 174: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 80...
Creando materiale Hysteretic con ID 175...
Errore nella creazione del materiale ID 175: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 81...
Creando materiale Hysteretic con ID 176...
Errore nella creazione del materiale ID 176: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 82...
Creando materiale Hysteretic con ID 177...
Errore nella creazione del materiale ID 177: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 83...
Creando materiale Hysteretic con ID 178...
Errore nella creazione del materiale ID 178: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 84...
Creando materiale Hysteretic con ID 179...
Errore nella creazione del materiale ID 179: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 85...
Creando materiale Hysteretic con ID 180...
Errore nella creazione del materiale ID 180: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 86...
Creando materiale Hysteretic con ID 181...
Errore nella creazione del materiale ID 181: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 87...
Creando materiale Hysteretic con ID 182...
Errore nella creazione del materiale ID 182: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 88...
Creando materiale Hysteretic con ID 183...
Errore nella creazione del materiale ID 183: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 89...
Creando materiale Hysteretic con ID 184...
Errore nella creazione del materiale ID 184: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 90...
Creando materiale Hysteretic con ID 185...
Errore nella creazione del materiale ID 185: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 91...
Creando materiale Hysteretic con ID 186...
Errore nella creazione del materiale ID 186: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 92...
Creando materiale Hysteretic con ID 187...
Errore nella creazione del materiale ID 187: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 93...
Creando materiale Hysteretic con ID 188...
Errore nella creazione del materiale ID 188: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 94...
Creando materiale Hysteretic con ID 189...
Errore nella creazione del materiale ID 189: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 95...
Creando materiale Hysteretic con ID 190...
Errore nella creazione del materiale ID 190: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 96...
Creando materiale Hysteretic con ID 191...
Errore nella creazione del materiale ID 191: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 97...
Creando materiale Hysteretic con ID 192...
Errore nella creazione del materiale ID 192: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 98...
Creando materiale Hysteretic con ID 193...
Errore nella creazione del materiale ID 193: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 99...
Creando materiale Hysteretic con ID 194...
Errore nella creazione del materiale ID 194: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 100...
Creando materiale Hysteretic con ID 195...
Errore nella creazione del materiale ID 195: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 101...
Creando materiale Hysteretic con ID 196...
Errore nella creazione del materiale ID 196: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 102...
Creando materiale Hysteretic con ID 197...
Errore nella creazione del materiale ID 197: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 103...
Creando materiale Hysteretic con ID 198...
Errore nella creazione del materiale ID 198: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 104...
Creando materiale Hysteretic con ID 199...
Errore nella creazione del materiale ID 199: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 105...
Creando materiale Hysteretic con ID 200...
Errore nella creazione del materiale ID 200: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 106...
Creando materiale Hysteretic con ID 201...
Errore nella creazione del materiale ID 201: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 107...
Creando materiale Hysteretic con ID 202...
Errore nella creazione del materiale ID 202: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 108...
Creando materiale Hysteretic con ID 203...
Errore nella creazione del materiale ID 203: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 109...
Creando materiale Hysteretic con ID 204...
Errore nella creazione del materiale ID 204: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 110...
Creando materiale Hysteretic con ID 205...
Errore nella creazione del materiale ID 205: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 111...
Creando materiale Hysteretic con ID 206...
Errore nella creazione del materiale ID 206: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 112...
Creando materiale Hysteretic con ID 207...
Errore nella creazione del materiale ID 207: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 113...
Creando materiale Hysteretic con ID 208...
Errore nella creazione del materiale ID 208: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 114...
Creando materiale Hysteretic con ID 209...
Errore nella creazione del materiale ID 209: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 115...
Creando materiale Hysteretic con ID 210...
Errore nella creazione del materiale ID 210: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 116...
Creando materiale Hysteretic con ID 211...
Errore nella creazione del materiale ID 211: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 117...
Creando materiale Hysteretic con ID 212...
Errore nella creazione del materiale ID 212: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 118...
Creando materiale Hysteretic con ID 213...
Errore nella creazione del materiale ID 213: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 119...
Creando materiale Hysteretic con ID 214...
Errore nella creazione del materiale ID 214: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 120...
Creando materiale Hysteretic con ID 215...
Errore nella creazione del materiale ID 215: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 121...
Creando materiale Hysteretic con ID 216...
Errore nella creazione del materiale ID 216: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 122...
Creando materiale Hysteretic con ID 217...
Errore nella creazione del materiale ID 217: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 123...
Creando materiale Hysteretic con ID 218...
Errore nella creazione del materiale ID 218: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 124...
Creando materiale Hysteretic con ID 219...
Errore nella creazione del materiale ID 219: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Leggendo riga 125...
Creando materiale Hysteretic con ID 220...
Errore nella creazione del materiale ID 220: 'MpcCaeDocument' object has no attribute 'createPhysicalProperty'
Script completato.
I attach the script below
Terminal
File Excel trovato.
Leggendo riga 6...
Leggendo riga 7...
Leggendo riga 8...
Leggendo riga 9...
Leggendo riga 10...
Leggendo riga 11...
Leggendo riga 12...
Leggendo riga 13...
Leggendo riga 14...
Leggendo riga 15...
Leggendo riga 16...
Leggendo riga 17...
Leggendo riga 18...
Leggendo riga 19...
Leggendo riga 20...
Leggendo riga 21...
Leggendo riga 22...
Leggendo riga 23...
Leggendo riga 24...
Leggendo riga 25...
Leggendo riga 26...
Leggendo riga 27...
Leggendo riga 28...
Leggendo riga 29...
Leggendo riga 30...
Leggendo riga 31...
Leggendo riga 32...
Leggendo riga 33...
Leggendo riga 34...
Leggendo riga 35...
Leggendo riga 36...
Leggendo riga 37...
Leggendo riga 38...
Leggendo riga 39...
Leggendo riga 40...
Leggendo riga 41...
Leggendo riga 42...
Leggendo riga 43...
Leggendo riga 44...
Leggendo riga 45...
Leggendo riga 46...
Leggendo riga 47...
Leggendo riga 48...
Leggendo riga 49...
Leggendo riga 50...
Leggendo riga 51...
Leggendo riga 52...
Leggendo riga 53...
Leggendo riga 54...
Leggendo riga 55...
Leggendo riga 56...
Leggendo riga 57...
Leggendo riga 58...
Leggendo riga 59...
Leggendo riga 60...
Leggendo riga 61...
Leggendo riga 62...
Leggendo riga 63...
Leggendo riga 64...
Leggendo riga 65...
Leggendo riga 66...
Leggendo riga 67...
Leggendo riga 68...
Leggendo riga 69...
Leggendo riga 70...
Leggendo riga 71...
Leggendo riga 72...
Leggendo riga 73...
Leggendo riga 74...
Leggendo riga 75...
Leggendo riga 76...
Leggendo riga 77...
Leggendo riga 78...
Leggendo riga 79...
Leggendo riga 80...
Leggendo riga 81...
Leggendo riga 82...
Leggendo riga 83...
Leggendo riga 84...
Leggendo riga 85...
Leggendo riga 86...
Leggendo riga 87...
Leggendo riga 88...
Leggendo riga 89...
Leggendo riga 90...
Leggendo riga 91...
Leggendo riga 92...
Leggendo riga 93...
Leggendo riga 94...
Leggendo riga 95...
Leggendo riga 96...
Leggendo riga 97...
Leggendo riga 98...
Leggendo riga 99...
Script completato.
Last edited by giulio.zanellato on Sat Jan 11, 2025 11:04 am, edited 1 time in total.
giulio.zanellato
SCript -API-6
from PyMpc import *
import os
from openpyxl import load_workbook
App.clearTerminal()
doc = App.caeDocument()
def run():
print("Inizio esecuzione script...")
# Verifica se il documento STKO è caricato
if doc is None:
print("Errore: Nessun documento attivo in STKO.")
return
print("Documento STKO caricato.")
# Percorso del file Excel
excel_file_path = os.path.join(os.getcwd(), "LibreriaSezione_fibreTamponamenti.xlsx")
print(f"Percorso file Excel: {excel_file_path}")
# Controllo del file Excel
if not os.path.exists(excel_file_path):
print(f"Errore: Il file {excel_file_path} non esiste.")
return
print("File Excel trovato.")
# Caricamento del file Excel
print("Caricamento del file Excel...")
workbook = load_workbook(filename=excel_file_path, data_only=True)
print("Caricamento del file Excel completato.")
# Selezione del foglio
sheet_name = "F (Minotto 2020)"
if sheet_name not in workbook.sheetnames:
print(f"Errore: Il foglio {sheet_name} non esiste nel file Excel.")
return
worksheet = workbook[sheet_name]
print(f"Sto leggendo il foglio: {sheet_name}")
# Definizione delle colonne per i dati
start_row = 6
end_row = 125
col_z = "G"
col_a = "H"
cols_params = ["K", "L", "M", "N", "O", "P", "Q", "R", "S", "T", "U"]
# Loop sulle righe dell'Excel per creare e configurare nuovi materiali
for row in range(start_row, end_row + 1):
print(f"Leggendo riga {row}...")
zi = worksheet[f"{col_z}{row}"].value
Ai = worksheet[f"{col_a}{row}"].value
params = [worksheet[f"{col}{row}"].value for col in cols_params]
if None in [zi, Ai] + params:
print(f"Riga {row}: Dati incompleti, salto questa riga.")
continue
# Estrazione dei parametri del materiale
s1, e1, s2, e2, s3, e3, pinchX, pinchY, damage1, damage2, beta = params
material_id = 101 + (row - start_row)
try:
print(f"Creando materiale Hysteretic con ID {material_id}...")
# Creazione di un nuovo materiale Hysteretic
material = doc.createPhysicalProperty("uniaxialMaterial", "Hysteretic")
material.XObject.getAttribute('tag').integer = material_id
material.XObject.getAttribute('s1').real = s1
material.XObject.getAttribute('e1').real = e1
material.XObject.getAttribute('s2').real = s2
material.XObject.getAttribute('e2').real = e2
material.XObject.getAttribute('s3').real = s3
material.XObject.getAttribute('e3').real = e3
material.XObject.getAttribute('pinchX').real = pinchX
material.XObject.getAttribute('pinchY').real = pinchY
material.XObject.getAttribute('damage1').real = damage1
material.XObject.getAttribute('damage2').real = damage2
material.XObject.getAttribute('beta').real = beta
# Salva il materiale nel documento STKO
doc.addPhysicalProperty(material)
print(f"Materiale creato e salvato: ID={material_id}")
except Exception as e:
print(f"Errore nella creazione del materiale ID {material_id}: {e}")
print("Script completato.")
# Main execution
if __name__ == "__main__":
run()
from PyMpc import *
import os
App.clearTerminal()
def run():
if doc is None:
return
return
return
start_row = 6
end_row = 125
col_z = "G"
col_a = "H"
continue
try:
# Main execution
run()
The function createPhysicalProperty does not exist.
This is how you can create physical properties
Here you can find the API reference:
https://asdeasoft.github.io/STKO-Python ... index.html
# create the XOBjectMetaData (i.e. the type of XObject)
meta = doc.metaDataPhysicalProperty('materials.uniaxial.Elastic')
# now you can create many instances of this type
for young_modulus in (1000.0, 2000.0, 3000.0):
# create the instance
xobj = MpcXObject.createInstanceOf(meta)
# edit its attributes
xobj.getAttribute('E').quantityScalar.value = young_modulus
# create a new property
prop = MpcProperty()
prop.id = doc.physicalProperties.getlastkey(0)+1
prop.name = 'Elastic Material ({})'.format(young_modulus)
# set the XObject in the property
prop.XObject = xobj
prop.commitXObjectChanges()
# add it to the document
doc.addPhysicalProperty(prop)
# done
doc.commitChanges()
doc.dirty = True
