MultiaxialCyclicPlasticity with initial analysis
Lei Lei
Post by Lei Lei » Tue Oct 29, 2024 1:51 pm
Hi everyone,
I'm trying to use the MultiaxialCyclicPlasticity constitutive model for an initial analysis, but it’s not included in the OpenSees documentation for constitutive models. I found the source code for this model on GitHub. By default, the material stage is set to 2 (plastic stage), but I need an elastic stage for the initial analysis.
It seems that the updateParameter function could change the stage, but it looks like a parameter needs to be defined first before calling updateParameter. I tried using parameter 1 element 1 material 1 MaterialStageID to define it, but this didn’t work.
Could anyone advise on how to set up this constitutive model for an initial analysis?
Thanks!
Re: MultiaxialCyclicPlasticity with initial analysis
Post by STKO Team » Thu Oct 31, 2024 11:26 am
Unfortunately that model does not implement the setParameter method that is used by OpenSees to understand if a material supports a given parameter name.
