Composite pushover
Posted: Wed Aug 14, 2024 10:21 am
I created a model of a steel-concrete composite member constituted of a concrete fiber section with lower and upper rebars embedded, and a steel section coupled to the concrete section through zeroLength elements. For the concrete section, I use concrete04. The steel parts use steel01 (lower and upper rebars) and steel02 for the coupled steel section.
It is a half-span model of a 4-point bending test, which I try to analyze in displacement control (the midspan node is the controlled node), to perform a pushover analysis.
My experience is, that the analysis becomes difficult when the elements get closer to the peak strength of the concrete constitutive law and softening initiates. I can add some robustness, when I use elastic materials for the rebars. Moreover, I see a kink in the lambda-midspan deflection curve when I switch to adaptive time steps, presumably due to concrete softening. It seems, that the analysis terminates for a good reason, but I believe some more increments should be possible with the displacement controlled algorithm.
I also tried to set up a monitor for the fiber strains. Is this possible? They did not appear in the monitor even after adding sections.fiber.strain to the recorder list.
Your suggestions would be very welcome. Thank you.
Kind regards,
Robert
Kind regards,
Robert
