Can't visualize stresses in beam elements
Posted: Fri Jul 05, 2024 10:12 am
by matsadriaenssen
Dear STKO Forum,
I have run a linear analysis of a steel lattice girder but I have some problems with the visualization of the stresses in the beam elements. I assigned them with an elastic section and a Lobatto integration scheme. The elements are force-beam elements.
I tried to record almost all of the possible things I can record as you can see in the picture but I still have not managed to see the stresses. The only thing I can see are stresses where I connected the beam elements with the solid piers. I can also not see any results if I want to make a beam/fiber plot. Can this be the issue or is it maybe a problem with the forcebeam element that I need to use an other elment.
All help is welcome .
Thank you in advance.
Kind regards,
Mats
Re: Can't visualize stresses in beam elements
Posted: Wed Jul 10, 2024 9:44 am
Hi, you can't see the stresses on elastic section. Please use "fiber" section, which can have Gauss points at each fiber location and display the stress and strain.
Posted: Thu Jul 11, 2024 12:52 pm
by matsadriaenssen
Thank you, this helps me a lot! I was already wondering if this might be the problem.
Kind regards,
Mats
Posted: Mon Jul 15, 2024 6:52 am
That's nice. You are welcome.
