Dear STKO-Team,
How can I extract the force-deformation curve of STKO?
Does anyone have results for the modelling of a shear wall which will be in reinforced concrete. So that I can compare my results.
Thank you for the Support!
Force-deformation curve
Re: Force-deformation curve
You can use monitor option. You might follow this,
[1]Select/add all the edge/nodes, where you want to record the force reaction, into a selection set (say, ReactionForce)
[2]Select/add all the node, where you want to record the displacement, into a selection set (say, DisplacementNode)
[3] Under Analysis Steps section, you can add a "monitor" screen, select ReactionForce for the Y-axis data and then DisplacementNode for the X-axis data.
The monitor option will show you the force-displacement graph in real-time, also the data are stored in the same location where the SCD file exists. You can manipuate this data separately in spreadsheet, if you want.
