STKO closes immediately
Posted: Thu May 30, 2024 4:00 am
by jpereirasan
Dear STKO team, i have the STKO 3.3 version installed in my desktop computer.
When i try to open an external SCD file, the program load the model but immediately closes.
How can i fix that problem?
(i can open models that i builded in my computer but not external SCD files from tutorials or this forum)
Re: STKO closes immediately
Posted: Thu May 30, 2024 7:25 am
That's strange. Is there a file from a particular webinar that doesn't work?
Posted: Fri May 31, 2024 3:29 am
by jpereirasan
I downloaded all the models from the STKO Model Database, STKO only works with the first model 0001_fibercolumn, all the other models close STKO immediately.
I attached the screenshots of what happen when i open a SCD file
Please help me to find a solution or find what is the cause of this problem
Posted: Fri May 31, 2024 7:42 pm
by jpereirasan
problem solved..... it was an issue with the GPU
Posted: Mon Jun 03, 2024 7:49 am
Yes. STKO requires at least OpenGL 2.1.
Posted: Sun Apr 20, 2025 2:59 am
by SUOSUO
hello,
I’m encountering the same issue, but my GPU should meet the requirements. Attached is my computer’s GPU information.
thanks.
Posted: Tue Apr 22, 2025 7:43 am
It's probably because you are on a laptop and by default applications start with the integrated GPU (which may not meet the requirements). Force STKO to start with the dedicated GPU (Nvidia in your case)
Posted: Fri Apr 25, 2025 4:42 am
by SUOSUO
Just to update you, the problem is solved. Thanks!
Posted: Mon Apr 28, 2025 8:16 am
