Sign conventions for Node and Element
Lei Lei
Post by Lei Lei » Thu May 16, 2024 1:13 pm
Dear STKOteam,
I have some questions regarding the sign conventions for Node and Element used in STKO.
1、For nodes, how are the positive and negative signs defined for the output items? Are these outputs based on the global coordinate system or influenced by local axes settings?
2、For elements, how are the positive and negative signs defined for the internal forces (Fx, Fy, Fz, Mx, My, Mz) in each direction? Additionally, for each degree of freedom, there are two equal values with opposite signs. How should these be distinguished?
Re: Sign conventions for Node and Element
Post by STKO Team » Fri May 17, 2024 8:53 am
Results are same as those in OpenSees
Nodal results are always in global coordinates
It depends on 1) the result type and 2) the element type.
For example:
  • In beams: "force" is in global coordinates "localForce" in local coordinates
  • "stress" in beams are in local coordinates, in solids are in global coordinates
There are two equal values with opposite signs
That makes perfect sense:
"force" are the beam's end-nodes forces: imagine a column with a vertical force F. The reaction will be -F. The axial force N will be equal to F, and the beam end-forces will be -F on top and +F on bottom
Lei Lei
Post by Lei Lei » Fri May 17, 2024 11:00 am
So, the two equal values with opposite signs are outputs for two ends of the element, and the order of the ends is arranged by local coordinates, right?
Post by STKO Team » Fri May 17, 2024 1:59 pm
The local X axis on a beam goes from first-node to last-node
Lei Lei
Post by Lei Lei » Fri May 17, 2024 2:03 pm
Thanks for your reply!
Post by STKO Team » Fri May 17, 2024 2:06 pm
