Dear STKOteam:
I want to simulate a 3D reinforced concrete beam.
I have a question about the building of steel bars.
Does the intersection of two steel bars affect the calculation? Just like in Figure 1.
If the center lines of two steel bars do not intersect but do intersect after being assigned a section, will it affect the calculation results? Just like in Figures 2 and 3.
Modeling of steel bar
Re: Modeling of steel bar
Not in this case. The overlap, by the do not intersect (i.e. they do not share a common node at the intersection)Does the intersection of two steel bars affect the calculation? Just like in Figure 1.
It will not affect anything, the section extrusion is just for visual purposes.If the center lines of two steel bars do not intersect but do intersect after being assigned a section, will it affect the calculation results? Just like in Figures 2 and 3.
Thanks for your reply!
Best wishes!
Best wishes!
