Hi everyone,
I'm new to Opensees/STKO and have a question about the "remove" command under the analysis options.
I'm currently modeling a monopile in sand. After completing the gravity analysis, I want to replace the soil body in the pile zone with a beam element (representing the pile). Should I only remove the soil elements in the pile zone using the "remove element xxx" command, or do I also need to remove the corresponding nodes?
Thank you for your help!
Best regards,
Ryan
RE: Remove command
Re: RE: Remove command
Check this webinar:
#022 Soil-Pile Interaction - Modeling with STKO's Python API
and also the last example in this
#024 Implicit-Explicit Contact Element Applied Examples: soil-foundation interaction and RC structures
All webinars are here:
https://asdea.eu/software/advanced-e-learning-courses/
