Constraints between two walls
Posted: Thu Jan 11, 2024 5:01 pm
I am attaching a model of a concrete structure that is made of two walls at a certain distance from one another.
The two walls are connected with some rebars that can be idealised with an interaction to which we can assign either equal dofs for horizontal displacements or as rigid bars.
In both cases, the system does not converge. However, if I remove such a constraint, the model runs.
Can you please help?
Best wishes,
Raffaele
Best wishes,
Raffaele
