Additional information on Pore pressure distribution and fixities
ryancwl95
Post by ryancwl95 » Mon Dec 04, 2023 12:30 pm
I am currently modeling a 1m thick semi-circular slice of soil within a larger soil body in transient gravity analysis at long time steps. I have set a 'no flow condition' (pore pressure degree of freedom = 0) at the top and bottom z-plane boundary nodes and along the Y-axis at the line of symmetry. At the radial boundary nodes, I am 'allowing for flow' (pore pressure degree of freedom = 1).
The obtained pressure profile is shown below:
Screenshot 2023-12-04 120247.png (118.36 KiB) Viewed 4204 times
The pressure profile around the top and bottom is -4.9 kPa to 4.9 kPa, respectively, resulting in a logical difference of 9.81 kPa for a 1m thick soil. I am curious about how the starting value of -4.9 kPa is determined.
I am also wondering about the creation of the pore pressure profile and why the pressure at the midpoint (roughly) of the slice is 0 kPa. Additionally, how is the 0 kPa reference line determined when calculating pore pressure?
When I set the outer radial boundary nodes with pore pressure degree of freedom = 0, the profile becomes:
Screenshot 2023-12-04 122423.png (90.93 KiB) Viewed 4204 times
Here, the pore pressure profile ranges from about 16.2 to 6.36 with a rough difference of 9.81 kPa. In this case, how is the starting value of 6.36 kPa at the top of the slice determined? Is there a reference line where the pore pressure profile is created/calculated?
Thank you for your assistance!
Re: Additional information on Pore pressure distribution and fixities
Post by STKO Team » Wed Jan 24, 2024 9:37 am
Can you share your model?
