The model does not converge.
Posted: Wed Aug 30, 2023 6:55 am
Dear STKO-Team
I am trying to build a simplified timber frame-shear wall model. The beam units are hinge beams element for articulation, and truss are created in the interior, with the upper truss connected to the beam-column nodes by equalDOF, and the lower truss and column cemented to the bottom.
The centres of the upper and lower truss are connected by a zero-length element, which has a material eigenstructure of Pinching4, to simulate the performance of the internal shear wall.
But the run results show the following problem, what is wrong with my model?
