Section fiber stress results visualization
Posted: Tue May 16, 2023 2:11 pm
Hello STKO Team,
I am trying to model a piping system and trying to visualize the portions of the pipe which would fail first or lets say the potions with the most stress. The stresses are as a result of Gravity Analysis and Time History Analysis.
For the Gravity Analysis, i have input the masses as node forces(Since i cannot run gravity analysis with giving masses as node forces) and for the time history analysis i have input the masses as line masses.
I have also length interactions, Zero length elements for modelling the spring under the supports. The spring behavior is expected in only lets say global z direction and for the other two, i used equal dof condition.
I have the following questions.
> Is it ok to specify masses via both node forces and line masses. I assumed that the gravity analysis will only take the masses( specified as node forces) and TH Analysis will only take the line masses automatically. Am i correct for this assumption?
> While defining the ZL Physical property we have to select among dirn 1, 2 and 3(3d, only displacement), whereas for the definition of equal dofs we see ux, uy and uz. My question is are these are local axes or global axes? I remember vaguely seeing it in one of your webinars but i cannot find it again. > The stresses values are not in line with the expected values. Could you possibly please check the model? I do not know what i am doing wrong.
> for checking the section forces like N, My, Mz and T, i can see it via the surface color map plot as well as the gauss point plot. Are they both the same ?
> Is it possible to view the max stress, max reaction forces etc. for a Time History analysis without having to see time steps one by one? Yes it should be point of max acceleration but still i am curious if we can just find the max.
> I used the following analysis steps. Gravity analysis followed by TH analysis. My question is should i be using wipe analysis option after the Gravity analysis or not, i want to see the cumulative effect of both of them? I compared the displacements and reaction forces in all 3 directions, with and without the wipe analysis option being selected, but the results were same. It should not be this, right?
I tried clearing the doubts via your videos or online help, but i was not able to find these fine points. It would be really helpful if you could help me on this. I am attaching the scd file as well in zip.
