I'm having problems creating a displacement controlled analysis with cyclic loading
I have convergence problem hovewer when I doing load control İt was working perfectly well
I would be very happy if you could take a look.
diplacement control-cyclic loading
halil.dincer
- column_cyclic.rar
- (108.31 KiB) Downloaded 123 times
Re: diplacement control-cyclic loading
You have a concrete material that does not have a final residual plateau in compression and at the same time a steel material that fractures. Under certain conditions, it will simply completely fail and there is no way you can compute equilibrium anymore
