Error of MPCO recorder when using Opensees MP
Zhou_Jx
Post by Zhou_Jx » Tue Jan 03, 2023 12:25 pm
Dear STKO,
When I use the Stko to conduct a seismic analysis via Opensees MP, a MPCORecorder FATAL Error: trial_ fiberdata. size () is happened. So what is wrong with it, could u help me to solve it.
Mpcorecorder Fatal error.jpg (83.84 KiB) Viewed 4479 times
Best wishes
Jiaxing.
Zhou_Jx
Re: Error of MPCO recorder when using Opensees MP
Post by Zhou_Jx » Tue Jan 03, 2023 1:50 pm
When I close the MPCO recorder, this error is solved. So how can I solve it?
Post by STKO Team » Tue Jan 03, 2023 2:39 pm
We just realized that due to a recent change in the Aggregator section in the latest OpenSees version, it gives wrong values for the MPCORecorder.
We already fixed, and before the next webinar in January you will be able to download a new OpenSees-Solvers installer from prof. tarque's website with this bug fixed.
In the meantime, do you really need the section aggregator? If not, you can just use beam-column elements without shear-deformability, otherwise you can record only a region of your model that does not include the elements with the section aggregator
Zhou_Jx
Post by Zhou_Jx » Wed Jan 04, 2023 6:09 am
Thanks for your reply!!
Post by STKO Team » Wed Jan 04, 2023 10:57 am
Ekrem Arda
Post by Ekrem Arda » Sat Mar 11, 2023 8:42 am
Please can someone share Prof. Tarque's kit couldn't find it in anywhere.
