Loft command
Loft command
Post by kesavapraba » Thu Mar 03, 2022 1:20 pm
Dear STKO Team
Can we use the "Loft" command between the edges of two faces? Before using Loft, I tried to explode the surfaces to get their basic objects, but the command aborted without splitting into its basic objects!
Actually, Is it possible to achieve doing loft between the edges? Thank you.
Re: Loft command
Post by STKO Team » Thu Mar 03, 2022 4:47 pm
Yes, you just need to go in sub-selection mode, because the edges you want to select are not floating edges, but borders of another geometry
Re: Loft command
Post by kesavapraba » Thu Mar 03, 2022 5:25 pm
Dear STKO Team
Got it. Thanks a lot.
Re: Loft command
Post by STKO Team » Fri Mar 04, 2022 9:26 am
