Adding nodal mass
kolozvari
Adding nodal mass
Post by kolozvari » Wed Jan 12, 2022 1:28 am
Hello, how can I add/assign nodal mass to a specific node in my model?
Thanks
Re: Adding nodal mass
Post by STKO Team » Thu Jan 13, 2022 6:03 pm
In Condition-> Mass
you can choose among:
NodalMass (mass assigned to a vertex)
EdgeMass (mass per unit length, assigned to an edge)
FaceMass (mass per unit face, assigned to a face)
VolumeMass (mass per unit volume, assigned to a solid)
The last 3 are automation that allow you to assign a distributed mass on a geometry, then STKO will take care of doing a consistent nodal lumping, obtaining the correct nodal masses to be used with the -mass option in the node command.
kolozvari
Post by kolozvari » Fri Jan 14, 2022 11:33 pm
Perfect, thank you!
Post by STKO Team » Tue Jan 18, 2022 2:11 pm
you're welcome
