mpiexec.hydra.exe.stackdump
Posted: Mon Jan 03, 2022 12:28 am
by spater
Re: mpiexec.hydra.exe.stackdump
Posted: Mon Jan 03, 2022 3:09 pm
What operating system are you using?
What OpenSees version?
Posted: Tue Jan 04, 2022 6:48 am
by spater
- This is my computer properties
- Screenshot 2022-01-04 144214.png (40.86 KiB) Viewed 7303 times
- This is the OpenSees-solvers
- Screenshot 2022-01-04 144411.png (36.71 KiB) Viewed 7303 times
It works normally on other computers, but not on this one. Could you help me solve it? Thank you very much.
Posted: Tue Jan 04, 2022 9:31 am
It should work on Windows 10.
Make sure hydra_pmi_proxy.exe and mpiexec.hydra.exe (in C:\OpenSees-Solvers\bin) are allowed by the firewall.
Make sure the antivirus is not blocking anything in C:\OpenSees-Solvers.
If you are not sure, download again the OpenSees-Solver installer, disable the antivirus, and install it again
Posted: Tue Jan 04, 2022 10:57 am
by spater
You mean WIN10pro is unable to use?
I shut down the firewall and antivirus on the WIN10pro, The same problem arises.
Posted: Tue Jan 04, 2022 4:56 pm
I mean that it should work without any problem on Windows 10. We only had some known issues with Windows 7.
Did you try to re-install OpenSees-Solvers while the antivirus is OFF?
Posted: Wed Jan 05, 2022 12:47 am
by spater
Yes I did. In fact, it worked fine the first time I used it on my workstation, but when I used it again a week later, I found this error.
Posted: Wed Jan 05, 2022 10:54 am
Well this is strange, it means something happened during that week. probably some new software or some windows settings?
Posted: Thu Mar 14, 2024 1:55 pm
by mlaur96
Hi! Did you manage to solve the problem in Windows 7? I am having the same error but using window 7
Posted: Fri Mar 15, 2024 1:48 pm
What is exactly your issue?
